Revision as of 12:30, 10 December 2014 by VMaslov (Talk | contribs)
What's this for
Equipment
PlayStation Move
Wii Remote with MotionPlus
Wii Remote Plus
  • PlayStation Move
  • Wii Remote with MotionPlus
Tip. To connect more than 4 PS Move controllers, more multiple Bluetooth adapters are usually needed. To use multiple Bluetooth adapters, it is necessary to install Motion in Joy drivers.
Getting into Recorder
Device list
    • Select + Move — White
    • Select + Cross — Blue
    • Select + Square — Magenta
    • Select + Triangle — Green
    • Select + Circle — Red
    • Select + T (Trigger) — Cyan
    • Select + Start — Yellow
    • Select + PS — Off
Tips on action video
Aiming at a camera
Standard grip
Now, the tips:
Tracking
Motion Controllers tab
Tutorials and demos
