Motion in Joy Installation
Revision as of 12:42, 10 December 2014 by VMaslov (Talk | contribs)
Pairing
Detection in iPi Recorder
== Multiple Bluetooth Adapters
To do this:
  • Run DS3 tool
  • Plug in ***one*** Bluetooth adapter
  • Install MotioninJoy drivers for it if necessary
  • [#Pairing|Pair] some PS Moves to this Bluetooth adapter
  • Unplug the Bluetooth adapter
  • Repeat for the next Bluetooth adapter and another portion of PS Moves
  • Plug in ***all*** Bluetooth adapters to use. Ensure they all have MotioninJoy drivers installed. This may not be the case if you plugged some of them into different USB ports than when pairing.
  • Exit DS3 tool
  • Turn all PS Moves on. Ensure they all successfully connect to corresponding Bluetooth adapters - red LED glows constantly.
  • Run iPi Recorder. All PS Moves should be listed in Device List.
Notes
N O T E   1:
N O T E   2:
    • click Driver Manager
    • click Roll back
N O T E   3:
N O T E   4:
N O T E   5:
