Motion in Joy Installation
- Currently (Jan 22, 2013) the latest version is 0.7.1001 which can be downloaded from the following direct link: http://www.xinputer.com/download/MotioninJoy_071001_signed.zip
- Note that for correct operation of this tool working Internet connection is required.
- Note that if your computer is equipped with more than one bluetooth adapters it's desirable to switch off or unplug all but one.
Pairing
Detection in iPi Recorder
Multiple Bluetooth Adapters
To do this:
- Run DS3 tool
- Plug in one Bluetooth adapter
- Install MotioninJoy drivers for it if necessary
- Pair some PS Moves to this Bluetooth adapter
- Unplug the Bluetooth adapter
- Repeat for the next Bluetooth adapter and another portion of PS Moves
- Plug in all Bluetooth adapters to use. Ensure they all have MotioninJoy drivers installed. This may not be the case if you plugged some of them into different USB ports than when pairing.
- Exit DS3 tool
- Turn all PS Moves on. Ensure they all successfully connect to corresponding Bluetooth adapters - red LED glows constantly.
- Run iPi Recorder. All PS Moves should be listed in Device List.
Notes
N O T E 1:
N O T E 2:
- Use the second bluetooth adapter to communicate with ordinal bluetooth devices.
- click Driver Manager
- click Roll back
N O T E 3:
N O T E 4:
N O T E 5:
