User Guide for Single Depth Sensor Configuration (printable version)
Revision as of 00:11, 9 December 2011 by Mini (Talk)
Software installation (Express edition)
  • unplug MS Kinect Sensor or Sony PS Eye cameras from computer
iPi Recorder is a tool for recording video from web cameras and depth sensors. Download the setup package of iPi Recorder latest version: http://ipisoft.com/downloads/iPiRecorderSetup.exe. Run it. In the following dialog window make sure that
  • item “PrimeSensor Driver (psdrv3) Registration for MS Kinect Sensor” is selected if you plan to work with Kinect
  • item “WinUSB Driver Registration for PS3 Eye Camera” is selected if you plan to work with Sony PS Eye cameras
Note that if you do not plan to use Sony PlayStation Eye cameras or Kinect then you can deselect the appropriate item in the list.
Also note that the latest version of iPi Recorder is compatible with Microsoft Kinect for Windows SDK. Thus if you have it installed then there is no need in “PrimeSensor Driver (psdrv3) Registration for MS Kinect Sensor”.
Click “Install” button to start the installation process. You’ll be asked about drivers installation:
At this point the drivers will complete installation and should not give any other errors:
After that, connect MS Kinect Sensor or Sony PS3 Eye cameras to your PC. Under Windows Vista and Windows 7 device initialization should be performed automatically and you’ll receive notification about it in the system tray area. Under Window XP you’ll be asked several times:
In all cases answer “No, not this time” and “Install the software automatically (Recommended)” respectively:
iPi Studio
Recording a video from a depth sensor
Environment
Side view
Top view
Actor Clothing
Recording Process
iPi Recorder Setup
Recording Actor's Performance
Performance Tips
  • Enter the actor.
  • Strike a T-pose.
  • Action
T-pose
Takes
Iterations
  • Record the videos
  • Give feedback to the actor
Takes
Naming conventions
Actor's performance
  • Enter the actor.
  • Strike a T-pose.
  • Action
T-pose
Takes
Iterations
  • Record the videos
Takes
Naming conventions
Processing a video from a depth sensor
  • Run iPi Mocap Studio
    3. Right mouse button up
  • Wait and watch...
Clean-up
Cleaning up tracking gaps
Cleaning up individual frames
Tracking refinement
Step 5
Step 5
Step 5
Step 6
Installation problems
How to report bugs and issues
