Revision as of 18:25, 9 June 2011 by Mini (Talk)
Tracking errors caused by wrongly configured background
This is a very common problem. It can be the source of most dramatic tracking errors.
First few seconds of your action video should have clear background (no actor in view of cameras). Failure to provide clear background will result in wrong operation of tracking algorithm.
You can quickly check your background by pushing and holding "Background" button at the top of iPiStudio window. If you see the actor in background then your background is wrong.
To fix this issue, you may need to re-shoot the video. If you have clear background at the end of your action video (or in some other part of your action video, for example, in the middle), you can fix the problem by moving the "Background" region on timeline.
Video codec problems
Potential problem: cannot open Kinect video in iPiStudio.
Possible cause: a broken Microsoft AVI Splitter installation.
One of the symptoms of this problem: unable to play Kinect video with Microsoft Media Player.
Usually this happens when users install third-party (non-Microsoft) video codecs.
At least a few users users reported this problem.
Solution:
1) For Windows XP - install (or re-install) Microsoft Media Player version 9.
2) For all platforms - the following command run with Admin rights should repair the default Microsoft AVI splitter installation:
regsvr32 quartz.dll
(On Windows7 use it like this: Start -> All programs -> Accessories -> Command Prompt -> (right click and select "Run as administrator") -> regsvr32 quartz.dll).
3) Installing XP Codec Pack may help.
We are working on a more reliable solution for this problem but it may take some time to implement.
Installation problems
Potential problem: after installation, iPiStudio crashes on first start.
Possible cause: very often, this is caused by incompatible video card. Another possible reason is broken .NET Framework installation of broken DirectX installation.
Low framerate and/or abnormally high CPU usage with Kinect
Potential problem: Low framerate and/or abnormally high CPU usage when recording a Kinect video with iPiRecorder.
Possible cause: bad USB cable or outdated Kinect driver.
Solution: Attach Kinect directly to computer USB port. Try different ports. Make sure Kinect power supply is not broken.
Check driver information for Kinect in Device Manager (make sure the Kinect sensor is attached to USB port because otherwise the Driver Manager won't display the info). The correct driver should be named "psdrv3.sys". If you have a different driver you may need to uninstall and delete it, then uninstall and then re-install iPiRecorder.
How to report bugs and issues
To send a video, please compress it with a suitable codec (to reduce the size), upload it to some file sharing server like filefactory.com and send us the link. For example, you can use Xvid codec and Virtual Dub for compression (Xvid and Virtual Dub are free).
IMPORTANT: When sending Kinect depth video, please do not compress it with traditional video codecs. Instead, please compress it with ZIP. Kinect depth video is very different from traditional video, and compressing it with a traditional lossy video codec distorts depth information. That's why you should use lossless compression (e.g. ZIP) with depth video.
