- for more info see USB controllers
- Storage system: HDD or SSD or RAID with write speed at least 55 Mb/sec
- Two Microsoft Kinect Sensors with separate power adapters
Software Installation
- Select needed components
- Important!
Components
iPi Recorder itself.
- that you can change motor position for each sensor using appropriate slider and “Motor of” combobox
- that you can switch between RGB and “depth” video using “View RGB/Depth” button
- that actual frame rate is 30 fps (or 29.9) and frames drop is in range from 0 to 5 for each sensor
Environment
Actor Clothing
Recording Process
Calibration
The first configuration
Preparations
- make sure that this calibration board is good visible in both sensors (the amount of yellow is low in the area of the veneer/plywood/cardboard/pasteboard).
Recording Calibration Video
- Start recording by pressing the "Start Video Recording" button.
- Initial two seconds of video should contain only background and static objects. Presence of actor or any moving objects in the initial two seconds of recorded video is unacceptable.
- Go to the capture area with prepared calibration plane (flat rectangular veneer/plywood/cardboard/pasteboard).
- Turn the veneer/plywood/cardboard/pasteboard to the left and to the right thus view angle is changing but the veneer/plywood/cardboard/pasteboard is still visible in both sensors.
- Stop the recording by pressing the "Stop Video Recording" button.
- At least two initial seconds of video contains only background and static objects (no actor, no calibration plane)
- The calibration plane is good visible on the depth maps most the time
- The calibration plane is moving and has at least 30 degrees variety in the horizontal view angle
- The amount of yellow points is relatively small
Processing Calibration Video
- Please make sure that the ground plane is determined correctly for both sensors after calibration video opening in the iPi Studio (to switch between sensors use buttons "Camera 1" and "Camera 2" in the top toolbar).
- Set the beginning of Region of Interest (ROI) to the point where calibration plane is good visible in both sensors.
- Adjust the end of ROI:
- the length of ROI should be at leat 5 seconds (150 frames)
- Go to the Calibration tab, select "Angle between sensors is 30 - 90 degrees" option and click "Calibrate Based on 3D Plane" button
- Please wait for the end of calibration process
- Evaluate the result:
- Save the result:
- go to the Scene tab
Video tutorial from TrueBones
The second configuration
Preparations
Recording Actor's Performance
Performance Tips
- Enter the actor.
- Strike a T-pose.
- Action
T-pose
Takes
Iterations
- Record the videos
- Give feedback to the actor
Takes
Naming conventions
Processing of performance video is generally the same as for single Kinect solution: Quick Start Guide with MS Kinect Sensor#Processing Video from Depth Sensor.
- switch to the Scene tab
- select file with scene parameters which has been saved during calibration process
- etc.
Clean-up
Cleaning up tracking gaps
Cleaning up individual frames
Tracking refinement
Export and Motion Transfer
Materials
Video
- From Greenlaw:
- From argus1000:
- From TrueBones:
Users' Feedback
Brilliant work guys. We just tested our setup with two Kinects at 90 degrees. As imagined, most of the occlusion issues are solved.
I'm seeing that dKS tracking is just slightly slower than with single Kinect tracking, but the time difference is negligible. With a single Kinect, I was getting about 0.67 sec per frame; with dKS I'm seeing about 0.7 sec per frame. I think that's very good for my graphics card. (My graphics card is a Nvidia GTX 460, which these days is probably considered a mid-range card.) At a glance, the dKS tracking results appears to be more stable than with a single Kinect.
Okay, I have several tracked dKS motions now and I just finished applying iPi Studio's Configurable Jitter Removal to a few clips. I have to say, this mocap looks incredibly solid! The results are far superior to the data I was getting using a single Kinect.
I have successfully calibrated the 180 degree angle with iPiSoft. It is great, it calibrates at 180 degrees producing a full 360 Hologram of myself in iPiSoft. The tracking is rock solid and the results are out of this world. I am utterly astonished. http://www.youtube.com/watch?v=WTyzFGJNGEo
