- Storage system: HDD or SSD or RAID with write speed at least 55 MByte/sec
- Two Microsoft Kinect sensors, or ASUS Xtion Live sensors, or PrimeSense Carmine 1.08 sensors
iPi Studio
Note that before you start working with two Kinects it's highly recommended to get appropriate results with single Kinect solution: User Guide with MS Kinect Sensor.
Software Installation
- Select needed components
- Important!
Components
iPi Recorder itself.
- that you can change motor position for each sensor using appropriate slider and “Motor of” combobox
- that you can switch between RGB and “depth” video using “View RGB/Depth” button
- that actual frame rate is 30 fps (or 29.9) and frames drop is in range from 0 to 5 for each sensor
iPi Studio
Environment
Actor Clothing
Recording Process
Calibration
The first configuration
Preparations
- make sure that this calibration board is good visible in both sensors (the amount of yellow is low in the area of the veneer/plywood/cardboard/pasteboard).
Recording Calibration Video
- Start recording by pressing the "Start Video Recording" button.
- Initial two seconds of video should contain only background and static objects. Presence of actor or any moving objects in the initial two seconds of recorded video is unacceptable.
- Go to the capture area with prepared calibration plane (flat rectangular veneer/plywood/cardboard/pasteboard).
- Turn the veneer/plywood/cardboard/pasteboard to the left and to the right thus view angle is changing but the veneer/plywood/cardboard/pasteboard is still visible in both sensors.
- Stop the recording by pressing the "Stop Video Recording" button.
- At least two initial seconds of video contains only background and static objects (no actor, no calibration plane)
- The calibration plane is good visible on the depth maps most the time
- The calibration plane is moving and has at least 30 degrees variety in the horizontal view angle
- The amount of yellow points is relatively small
Processing Calibration Video
- Please make sure that the ground plane is determined correctly for both sensors after calibration video opening in the iPi Studio (to switch between sensors use buttons "Camera 1" and "Camera 2" in the top toolbar).
- Set the beginning of Region of Interest (ROI) to the point where calibration plane is good visible in both sensors.
- Adjust the end of ROI:
- the length of ROI should be at leat 5 seconds (150 frames)
- Go to the Calibration tab, select "Angle between sensors is 30 - 90 degrees" option and click "Calibrate Based on 3D Plane" button
- Please wait for the end of calibration process
- Evaluate the result:
- Save the result:
- go to the Scene tab
Video tutorial from TrueBones
The second configuration
Preparations
Recording Actor's Performance
Performance Tips
- Enter the actor.
- Strike a T-pose.
- Action
T-pose
Takes
Iterations
- Record the videos
- Give feedback to the actor
Takes
Naming conventions
Processing of performance video is generally the same as for single Kinect solution: User Guide with MS Kinect Sensor#Processing Video from Depth Sensor.
- switch to the Scene tab
- select file with scene parameters which has been saved during calibration process
- etc.
Clean-up
Cleaning up tracking gaps
Cleaning up individual frames
Tracking refinement
Export and Motion Transfer
Installation problems
How to report bugs and issues
Video Materials
- From Greenlaw:
- From argus1000:
- From TrueBones:
