User Guide for Multiple PlayStation Eye Cameras Configuration
Revision as of 16:58, 14 December 2011 by Pavel (Talk)
    • Storage system: HDD or SSD or RAID with write speed:
      • For 4 cameras at 60 fps, 640 x 480 resolution: not less than 70,4 MByte/sec
      • For 6 cameras at 60 fps, 640 x 480 resolution: not less than 105,6 MByte/sec
Note If your write speed is lower, you can work with 320 x 240 resolution and/or lower frame rate. Alternatively, you can use compressed mode (that gives 3-5 times lower required write speed, but the CPU performance may become a bottleneck)
iPi Studio
Software Installation
  1. Select needed components
Important!
Components
    iPi Recorder itself.
Important! You can plug not more than 2 cameras to one USB controller, otherwise you will not be able to capture at 60 fps with 640 x 480 resolution. For more info see USB controllers
iPi Studio
Recording Video with Multiple PlayStation Eye Cameras
Environment
Space
For a multiple PlayStation Eye configuration, you need a minimum of 13 feet by 13 feet space (4 meters by 4 meters). At smaller space, actor simply won’t fit into view of cameras.
Background
Lighting
Actor Clothing
Special considerations
Don’t stand too close to a wall. Shadows on the wall may confuse the system. If standing close to a wall is unavoidable you should use additional light sources to light the wall behind actor to minimize shadows.
Recording Process
iPi Recorder Setup
Framerate
4 cameras at 320 by 240 resolution
4 cameras at 640 by 480 resolution at 60 frames per second
6 cameras at 640 by 480 resolution at 60 frames per second
USB controllers
Scene Set-up
Three Camera Configuration
Recommended configuration for 3-camera setup is a half-circle:
Example:
Virtual view of the same scene:
Four Camera Configuration
You can set up 4 cameras in a half-circle or a full-circle configuration, depending on available space. You can improve accuracy by placing one of the cameras high over the ground (like 3 meters high).
Recommended configuration for 4-camera setup in half circle:
Example:
Six Camera Configuration
You can set up 6 cameras in a full-circle or a half-circle configuration, depending on available space. You can improve accuracy by placing one or two cameras high over the ground (like 3 meters high).
Recommended configuration for 6-camera full-circle setup:
Camera Setup
Install the cameras on tripods and connect cables.
Sony PlayStation Eye cameras do not have standard tripod mounting screw, so you will have to use some kind of ad hoc solution. The simplest approach is to fix the cameras to tripods using sticky tape.
When mixing active and passive USB cables, make sure cable connection order is correct (computer->active cable->passive cable->camera).
If you're using the PlayStation Eye camera, make sure you have the lens set to the wide setting.
Calibration
Importance of high frame rate
Glowing Marker
Start video recording.
Tip. For successful calibration, several hundred frames are sufficient. Much more frames (like several thousands) will not produce more accurate results, but instead will increase the processing time and possible number of marker detection errors. So generally it is not recommended to record calibration videos of more than 1 minute length.
Tip. You should make the marker visible to as much cameras as possible at all times. Hold the marker in the straight arm away from your body. In a circle configuration, when approaching the boundary of the capture area, position the marker inside the area, and your body outside.
  • Most of the time marker is visible in at least 3 cameras and not completely obscured by human body
Step 5: process calibration video in iPi Mocap Studio
  • Load your calibration video to iPi Mocap Studio
  • Important. Adjust the Region of Interest to cover the part of video that contains the glowing marker.
  • Set the Diagonal Field of View (FOV) for your cameras on the “Scene” tab. If you use Sony PlayStation Eye or Logitech QuickCam 9000 cameras, leave the FOV value at the default 75 degrees.
  • Go to “Calibration” tab. Check “Auto detect initial camera positions” checkbox. Click “Calibrate” button and wait while the system finishes calibration.
  • Calibration algorithm may occasionally fail to find correct camera positions. If this happens, you should manually adjust initial camera positions to roughly match your configuration. The main thing is the correct order of the cameras around the capture area, and their approximate view directions.
    • Reset camera positions with one of the standard half-circle or full circle configurations that best suits your configuration.
    • For each camera that requires adjusting, switch to this camera using the toolbar button, and correct its position using controls on the “Scene” tab.
    • Uncheck “Auto detect initial camera positions” checkbox.
    • Click “Calibrate” button. This will rerun calibration process, without recomputing marker positions.
Follow video tutorial:
Tip. When doing manual camera positioning before the calibration, you may find useful to match model's position with the actor on a video:
  • Select the frame where the actor is standing relatively straight.
  • Show the model by checking the "View > Skin" menu item.
  • Adjust the camera position to fit the model with the actor's image.
Step 6: Define ground plane
Step 8: Save calibration result into *.scene.xml file
Recording Actor's Performance
  • Enter the actor.
  • Strike a T-pose.
  • Action
T-pose
Takes
Iterations
  • Record the videos
  • Give feedback to the actor
Takes
Naming conventions
Processing Video from Multiple PlayStation Eye Cameras
Open multi-camera video in iPi Mocap Studio. Load scene configuration from file.
Adjust the Region of Interest (ROI). (Region of Interest should cover the part of video that contains the motion).
Go to T-pose frame. Using character Move/Rotate controls, roughly align the model with the image of actor in one view. Adjust character height and proportions (on Actor tab) to correspond to actor.
Push the Analyze Appearance button on Actor tab to automatically adjust model's colors. For the multi-camera video, Analyze Appearance button uses only one (current) camera. This makes it easier to align model with image. You can refine actor appearance by alternating Refit Pose and Analyze Appearance. Also you can edit the colors manually or with the eyedropper tool.
Go to the first frame of Region of Interest (ROI). Push the Refit Pose button on Tracking tab. If initial pose was recognized incorrectly, you can roughly adjust it manually and use auto-fit again.
Push the Track Forward button on Tracking tab.
You can save your motion capture project to a file. If your project is saved to a file, then the system will auto-save it after each processed frame during tracking.
Refer to video tutorial for tips on video processing:
Clean-up
Cleaning up tracking gaps
Cleaning up individual frames
Tracking refinement
Export and Motion Transfer
Step 5
Step 5
Step 5
Step 6
Installation problems
How to report bugs and issues
Video Materials
For video materials please refer to our Gallery
