- Microsoft Kinect Sensor (“Depth Sensor”) with separate power adapter
Software Installation
- Select needed components
- Important!
Components
iPi Recorder itself.
- Note that values of Tilt and Roll are updated with a time lag. During recording these values cannot be updated assuming that in this case sensor should be static.
iPi Studio
Environment
Actor Clothing
Recording Process
- Important! Initial two seconds of video should contain only background and static objects. Presence of actor or any moving objects in the initial two seconds of recorded video is unacceptable. It’s because initial seconds of video are used to calculate static background necessary to separate actor from other objects of 3D scene.
- Run iPi Studio
- Press Ctrl+O or push “Open” button on toolbar
- Choose recorded avi file
- In the “Select Video Layout” dialog select the following values:
- Depth video from MS Kinect Camera
- Numbers of cameras: 1
- Resolution: 640x480
- Right mouse button up
- Save created project by pressing Ctrl+S or pushing button “Save” on toolbar
- Switch to “Tracking” tab and push “Refit pose” button.
- As a result model should be matched with actor image from video. If it does not happen then delete result using item “Edit” -> “Delete pose” from main menu and repeat above actions.
- Using the slider right to the button “Show Skin” in toolbar, make sure that morph of model corresponds to the actor image. If no, than adjust arms/torso/legs morph using appropriate sliders from “Actor” tab.
- Switch to “Tracking” tab, check “Enable foot tracking” and “Enable shoulders tracking” checkboxes
- To start tracking just push “Track Forward” button
- Wait and watch...
Clean-up
Cleaning up tracking gaps
Cleaning up individual frames
Tracking refinement
Export and Motion Transfer
Video Materials
Demo video
"Car scene" by JeanDellac
Animation by NextGenReport
"First results" from Radiac
See also:
Frequently Asked Questions
Q: Is tracking realtime?
A: No, not yet.
Q: What about head tracking?
Q: Is FBX format supported?
A: Yes.
Q: What does "iPi DMC" means?
- iPiRecorder - a tool for recording video from web cameras and depth sensors;
- iPiStudio - software application for processing pre-recorded video and exporting resulting animation.
A: You can buy online.
