Revision as of 18:22, 9 December 2011 by Pavel (Talk)
Software Installation
  1. Select needed components
Important!
Components
    iPi Recorder itself.
iPi Studio
Environment
Side view
Top view
Actor Clothing
Recording Process
Recording Actor's Performance
Performance Tips
  • Enter the actor.
  • Strike a T-pose.
  • Action
T-pose
Takes
Iterations
  • Record the videos
  • Give feedback to the actor
Takes
Naming conventions
  • Run iPi Studio
  • Choose recorded avi file
    • Numbers of cameras: 1
    • Resolution: 640x480
    3. Right mouse button up
  • Wait and watch...
Clean-up
Cleaning up tracking gaps
Cleaning up individual frames
Tracking refinement
Export and Motion Transfer
Step 5
Step 5
Step 5
Step 6
Video Materials
Demo video
"Car scene" by JeanDellac
Animation by NextGenReport
"First results" from Radiac
See also:
Frequently Asked Questions
Q: Is tracking realtime?
A: No, not yet.
Q: What about head tracking?
Q: Is FBX format supported?
A: Yes.
Q: What does "iPi DMC" means?
  • iPiRecorder - a tool for recording video from web cameras and depth sensors;
  • iPiStudio - software application for processing pre-recorded video and exporting resulting animation.
A: You can buy online.
