Calibration
Revision as of 22:49, 22 March 2011 by Andrew (Talk)
Calibration is the process of computing accurate camera positions and orientations from a video of user waving a small glowing object (called “marker”). This step is essential and required for multi-camera system setup.
VERY IMPORTANT: Once you calibrated the camera system, you should not move your cameras for subsequent video shoots. If you move at least one camera, you need to perform calibration again.
Glowing Marker
Run iPiRecorder and turn on Calibration mode checkbox (for Sony PS Eye cameras)
Important: Do not turn off the light in the room during calibration! This will not help the software but will make it harder for you to see what is happening on recorded video when you view it later.
Start video recording. First couple of seconds of calibration video should contain background only (no marker). Then move slowly the marker through your entire capture volume (front-top-right-bottom-left-back-top-right-bottom-left). Start from top and move the marker in a descending spiral motion.
Put the marker to the ground at each corner and at the center of capture volume.
  • First two seconds of video do not contain marker
  • Most of the time marker is visible in at least 3 cameras and not completely obscured by human body
Step 5: process calibration video in iPiStudio
  • Load your calibration video to iPiStudio
  • VERY IMPORTANT: Adjust the Region of Interest to cover the part of video that contains the glowing marker.
  • Set the Diagonal Field of View (FOV) for your cameras on the “Scene” tab. If you use Sony PlayStation Eye or Logitech QuickCam 9000 cameras, leave the FOV value at the default 75 degrees.
  • Set initial positions of cameras. Move and rotate virtual cameras so that their positions and orientations very roughly correspond to real positions and orientations. Click “Calibrate” button on “Calibration” tab and wait while the system finishes calibration.
  • Calibration algorithm may occasionally fail to find correct camera position. In particular, this may happen if left and right cameras are swapped. If this happens, move virtual cameras using camera orbit control on “Scene” tab and click “Calibrate” again. This will cause calibration (but not marker tracking) to be repeated.
Follow video tutorial:
Step 6: Define ground plane
Step 8: Save calibration result into *.scene.xml file
