- Microsoft Kinect sensor, or ASUS Xtion Live sensor, or PrimeSense Carmine 1.08 sensor
iPi Studio
Software Installation
- Select needed components
- Important!
Components
iPi Recorder itself.
- Note that values of Tilt and Roll are updated with a time lag. During recording these values cannot be updated assuming that in this case sensor should be static.
iPi Studio
Environment
Actor Clothing
Recording Process
Recording Actor's Performance
Performance Tips
- Enter the actor.
- Strike a T-pose.
- Action
T-pose
Takes
Iterations
- Record the videos
- Give feedback to the actor
Takes
Naming conventions
- Run iPi Mocap Studio
- Press Ctrl+N or push New button on toolbar to create new project
- Choose recorded *.iPiVideo file
- Right mouse button up
- Save created project by pressing Ctrl+S or pushing button Save on toolbar
- Adjust actor height using appropriate slider on tab Actor
- Select Move tool on toolbar.
- Switch to Tracking tab and push Refit pose button.
- As a result model should be matched with actor image from video. If it does not happen then delete result using item Edit > Delete pose from main menu and repeat above actions.
- Using the slider right to the button Show Skin in toolbar, make sure that morph of model corresponds to the actor image. If no, than adjust chest/bust/waist/hips/belly morph using appropriate sliders from Actor tab.
- Switch to Tracking tab, change tracking options (Head tracking, Shoulders and Spine) if required.
- To start tracking just push Track Forward button.
- Wait and watch...
Clean-up
Cleaning up tracking gaps
Cleaning up individual frames
Tracking refinement
Export and Motion Transfer
Installation problems
How to report bugs and issues
Video Materials
Demo video
"Car scene" by JeanDellac
[ http://www.youtube.com/watch?v=L7cGwPrZjh4 Click to view]
Animation by NextGenReport
