IPi Mocap Studio Changelog
Revision as of 22:47, 8 March 2013 by Andrew (Talk | contribs)
ver. 2.3.0.148
Version 2.3.0.148
Mar 08, 2013
Download-24.png  Download
 B U G    F I X E S:
ver. 2.3.0.147
Version 2.3.0.147
Feb 26, 2013
 B U G    F I X E S:
ver. 2.3.0.146
Version 2.3.0.146
Feb 25, 2013
 N E W    F E A T U R E S:
  • Changes in timeline:
  • Tracking option for spine:
    • Removed 90/180 degrees setting (no longer needed - auto-detected in new version).
 B U G    F I X E S:
ver. 2.2.1.145
Version 2.2.1.145
Jan 18, 2013
  • Tracking improvements:
    • Improved spine tracking.
  • UI improvements:
Refine Pass
Color Picker Tools
Time Line Zoom
ver. 2.2.0.144
Version 2.2.0.144
Dec 13, 2012
    • Go to parent bone ([)
  • Improved actor's model.
 B U G    F I X E S:
ver. 2.1.3.143
Version 2.1.3.143
Nov 23, 2012
    • Copy Pose of Selected Bone - copies rotations for selected bone to Clipboard. For paste use Paste Pose menu item.
    • Copy Pose of Selected Bone with Children - copies rotations for selected bone and all its children to Clipboard. For paste use Paste Pose menu item.
  • If video from depth sensors like MS Kinect or ASUS Xtion has RGB channel then now you can colorize 3D point cloud using data from RGB camera. To turn on this feature please use View -> Color Point Cloud with RGB Data menu item.
  • Added iPiMocap: namespace only for MotionBuilder-optimized FBX output (Export -> For MotionBuilder (FBX, BVH) menu item).
 B U G    F I X E S:
ver. 2.1.2.142
Version 2.1.2.142
Nov 08, 2012
 B U G    F I X E S:
ver. 2.1.2.141
Version 2.1.2.141
Nov 07, 2012
ver. 2.1.1.140
Version 2.1.1.140
Oct 13, 2012
  • Small UI improvements:
Select bone
MRU project list
Export animation button
ver. 2.1.0.139
Version 2.1.0.139
Sep 30, 2012
UI changes
  • More compact project files.
 B U G    F I X E S:
ver. 2.0.1.138
Version 2.0.1.138
Aug 04, 2012
Note. To turn off this alignment one can use View -> Align Color Video to Depth menu item.
ver. 2.0.0.137
Version 2.0.0.137
Jul 19, 2012
 B U G    F I X E S:
ver. 2.0.0.135
Version 2.0.0.135
Jul 03, 2012
 B U G    F I X E S:
ver. 2.0.0.134
Version 2.0.0.134
Jun 30, 2012
  • Support for any order of Euler angles in FBX export. This is especially useful for LightWave users. See this topic list for discussions about this problem.
 B U G    F I X E S:
ver. 2.0.0.133
Version 2.0.0.133
Jun 17, 2012
 B U G    F I X E S:
ver. 2.0.0.132
Version 2.0.0.132
Jun 13, 2012
 B U G    F I X E S:
ver. 2.0.0.131
Version 2.0.0.131
Jun 07, 2012
 B U G    F I X E S:
ver. 2.0.0.130
Version 2.0.0.130
Jun 02, 2012
  • Different menu item and toolbar button for creating new project (File -> New project… and New respectively).
  • File -> Open is renamed to File -> Open project… and now opens only project files.
  • File -> Import animation menu item is renamed to File -> Open animation…
 B U G    F I X E S:
ver. 2.0.0.129
Version 2.0.0.129
Jun 01, 2012
  • New skeleton.
  • New project wizard.
  • Improved foot tracking.
  • Improved shoulder tracking.
