Installation problems
- Some systems (for example some laptops and older Mac Minis) have both integrated graphics and discrete graphics. You may need to disable integrated graphics when working with iPi Mocap Studio. To do this, please use tools offered by your discrete GPU video card manufacturer (e.g. Nvidia or AMD).
How to report bugs and issues
