IPi Recorder Changelog
Revision as of 14:13, 4 November 2014 by Andrew (Talk | contribs)
ver. 2.2.3.30
Version 2.2.3.30
Jun 14, 2014
Download-24.png  Download
 N E W    F E A T U R E S:
  • Added support for newer model of Wii Remote Plus. This requires using Toshiba Bluetooth stack.
    Actually, this model has been around for quite a while (since 2012). But it seems that all users, which employed Wii Remotes with our software before, have the older model.
ver. 2.2.2.29
Version 2.2.2.29
Mar 07, 2014
 B U G    F I X E S:
  • Fixed app crash on certain hardware configurations, related to audio input.
ver. 2.2.2.28
Version 2.2.2.28
Dec 26, 2013
 B U G    F I X E S:
  • Fixed support for PS Move controllers on Windows 8.1 (using Motion-in-Joy drivers).
ver. 2.2.2.27
Version 2.2.2.27
Oct 04, 2013
  • Elevation angle for Kinect and PS Move sphere color can be changed right from on-screen controls (no need to press the PROPERTIES button). Accessible at any screen, not only at Setup.
  • The new RESET DEVICES button at the Record screen allows to recover from certain errors occurred during recording without the need to return back to the Devices screen.
    When some device switches to error state (usually there is a red message on its screen), use this button to try to recover. Beforehand, check that there is no hardware failure like disconnected cable. If the device does not recover after several tries, return to the Devices screen or restart the program.
  • Motion controllers shortcuts in tooltips for START / STOP / EVALUATE buttons. For those who forget or does not still know :)
  • Installer now installs Kinect SDK 1.8 (previously was 1.6). Versions 1.6 through 1.8 are supported.
 B U G    F I X E S:
  • Fixed occasional crashes when opening an iPiVideo file from Windows Explorer.
  • Fixed incorrect camera screen layout after the background evaluation.
  • Improved behavior at recording startup to prevent false Hang-up detected errors.
  • Necessary components, which are (rarely) not present on a user system, were added to the installer.
ver. 2.2.1.25
Version 2.2.1.25
Sep 10, 2013
  • Export of video from individual cameras to an AVI file.
    Use the EXPORT button on the Converter tab to add an export task. Choose iPiVideo file, select the channel corresponding to a camera of interest (use preview to identify it), then specify AVI file name and compression options. Now click ADD and wait for export to complete, or create the next task.
    Currently, only color channel can be exported from depth sensor videos.
 B U G    F I X E S:
  • Fixed unstable work of ASUS Xtion / Carmine sensors in certain conditions.
  • Prevented unintentional change of Kinect's elevation angle during the application start.
  • Fixed error in connecting Wii Remote controllers.
New buttons on Converter tab
Input for an export task
Output for an export task
ver. 2.2.0.24
Version 2.2.0.24
Jun 11, 2013
  • Audio recording capability.
    Recording is possible with just one of available audio inputs. Select a microphone at the Devices stage. At the Setup stage you can change your selection and also set the desired audio quality.
  • Basic file operations: rename, delete, open containing folder.
    These operations are available in player, recent records list, conversion tasks list. In recent records list, the only visible action by default is Play. To see other available actions, press on the vertical ellipsis to the right from the Play button.
  • Improved synchronization of the cameras during recording.
 B U G    F I X E S:
  • Fixed handling of the time stamp placeholder in a record's file name.
Available microphones
Audio settings and microphone levels
File operations and sound controls in player
ver. 2.1.6.23
Version 2.1.6.23
Apr 09, 2013
  • Improved performance with Motion in Joy Bluetooth drivers
    This should remove (or at least greatly reduce) freezing issues that some users experienced on Windows 8 when recording with PS Move.
 B U G    F I X E S:
  • Fixed app crash on exhausting the disk space while recording.
    The recording ends slightly before reaching critical remaining disk space values. This is especially actual for users employing a RAM drive for recording.
ver. 2.1.5.22
Version 2.1.5.22
Mar 22, 2013
  • Compatibility with Kinect SDK 1.7
    Note: Both versions of Kinect SDK are supported: 1.6 and 1.7. iPi Recorder installation program still suggests version 1.6 of Kinect SDK. Anyway, you are free to use any of these versions — tracking quality is the same.
ver. 2.1.4.21
Version 2.1.4.21
Mar 18, 2013
  • Official support for PrimeSense Carmine sensor.
    It was implicitly supported in previous versions recognized as ASUS Xtion Live. Now it is detected separately, though there is an opposite issue of recognizing ASUS Xtion Live with updated firmware as Carmine.
  • Main window size and state (whether it is maximized) are automatically restored on the application startup.
 B U G    F I X E S:
  • Fixed data cut-off issue when using the background subtraction compression for depth data.
    This issue particularly affected feet at the floor.
  • Fixed improper behavior when changing video mode after recording in certain situations.
  • Fixed app crash when setting JPEG compression quality to 0.
    Minimum JPEG quality value has been raised to 30 to prevent very low quality recordings.
PrimeSense Carmine 1.08
ver. 2.1.3.20
Version 2.1.3.20
Jan 22, 2013
ver. 2.1.2.19
Version 2.1.2.19
Dec 03, 2012
  • Taking advantage of new features of Kinect SDK 1.6:
    • depth data is not limited by 4 meters now
    • color image from Kinect is obtained as raw Bayer rather then decoded RGB which allows to improve performance of recording and reduce size of resulting *.iPiVideo file
    • PROPERTY page for Kinect for Windows devices now contains settings for color camera (see screenshot). Note that this feature is not available for Kinect for XBOX
  • Significant performance improvements
New properties of Kinect for Windows
ver. 2.1.1.18
Version 2.1.1.18
Nov 25, 2012
  • Support for Nintendo Wii Remote Plus motion controller
  • Moved to Microsoft Kinect SDK 1.6
    Warning. Kinect SDK 1.6 should be installed to get support for Kinects with this version of iPi Recorder.
  • Start/stop recording using a motion controller. Hold the button for a couple of seconds to toggle recording. Also works when starting background evaluation.
    • Start button on PS Move
    • A button on Wii Remote
  • Indication of battery charge level for motion controllers
  • Sequential background evaluation for depth sensors. This removes infrared interference effects on background picture.
    Tip. In case you are going away from PC when evaluating background, be aware that now for dual sensor configuration, background evaluation lasts about twice the duration setting.
  • Detecting when too many cameras are connected to a single USB controller
  • Optimizing application performance (especially startup time) for the system on which it is installed (using NGen)
    tools > optimize app menu item
  • Launching Windows Device Manager directly from the menu
    tools > device manager menu item
  • Improved persistence of settings for motion controllers
 B U G    F I X E S:
  • Mixing up of Kinect motor controls occasionally when using PrimeSense drivers
Battery charge level
ver. 2.1.0.17
Version 2.1.0.17
Nov 03, 2012
  • Support for motion controllers — Sony PlayStation Move and Nintendo Wii Remote (with Motion Plus)
    This enables props/hands tracking in iPi Mocap Studio (update with these capabilities will be available in the next 2-3 weeks). See our Getting Started guide.
  • Video information panel in player
    Expand it from the right edge of the window and explore all information stored in iPiVideo file: camera models, property values used during recording, statistical data, etc.
  • Little UI improvements, including:
    • auto hiding on-screen controls when the mouse is still for a while
    • auto selecting value for devices in a row (cameras in a row in previous versions) depending on the number of devices
  • Decreased memory usage.
Motion controller (right)
Video info panel
ver. 2.0.0.15
Version 2.0.0.15
Oct 01, 2012
  • Improved alignment of depth and color images.
    Device-specific parameters are obtained for each depth sensor and written to iPiVideo file during recording. This gives high accuracy of aligning depth and color images in iPi Mocap Studio. Implemented both for Microsoft Kinect and ASUS Xtion Live.
  • Opening video in iPi Mocap Studio with one click.
    Each recorded or converted video file in addition to existed Play button now has Open In Studio button (icon is letter "S"). Press this button, and (if installed) iPi Mocap Studio will launch with the New Project wizard open for the selected video file.
  • New help menu.
    Contains user's guide, release notes and EULA.
  • Further performance improvements
 B U G    F I X E S:
  • Frame drops statistics were not counted properly for ASUS Xtions.
  • Under certain circumstances empty video were recorded (containing no frames).
  • The installer won't run on Windows XP x64.
ver. 2.0.0.14
Version 2.0.0.14
Jul 21, 2012
  • Improved error handling.
 B U G    F I X E S:
ver. 2.0.0.13
Version 2.0.0.13
Jun 14, 2012
WARNING. iPi Mocap Studio prior to version 2.0.0.132 may not open videos recorded with this release of iPi Recorder. Ensure that you're using the latest version of iPi Mocap Studio (see version info in Help > About window). In case you need an update, try restarting application (an automatic update should launch), or download and run the latest installer from the downloads page at our website. Videos recorded with previous versions of iPi Recorder can still be opened by any version of iPi Mocap Studio.
ver. 2.0.0.12
Version 2.0.0.12
Jun 05, 2012
 B U G    F I X E S:
ver. 2.0.0.11
Version 2.0.0.11
Jun 05, 2012
 B U G    F I X E S:
ver. 2.0.0.10
Version 2.0.0.10
Jun 01, 2012
