IPi Mocap Studio Changelog
ver. 2.6.0.161
N E W F E A T U R E S:
- iPi Biomech Add-on released.
- This is a tool for in-depth biomechanical analysis of human motions. It includes visualization of tracking data and its export to various formats.
- Note that Add-on is not a free update and requires separate license key. 30-days free trial is available. For more information please read Biomechanical Analysis article.
- Reliable saving of project files ensures that project file will not be corrupted even if system crash occurs during saving operation
- Increased performance of hand / fingers keyframing
B U G F I X E S:
- Color picker tool did not work when Move or IK tools were selected
- Program crash in case when Jitter removal runs with View->Pose Mismatch option checked
- Program crash during calibration with Auto-detect initial camera positions enabled under certain conditions
ver. 2.5.1.159
- Manual position adjustment of gyro sensors using Move tool
B U G F I X E S:
- Not enough precision of Euler Angles near Gimbal Locks during export to BVH, FBX and SMD. This bug was introduced in the previous version.
ver. 2.5.0.158
- Experimental support for triple depth sensor configuration. For more information please read Getting Started article. This functionality is available in Standard edition only. In other editions you can try it but export will be disabled.
- List of options for spine flexibility is extended:
| New Value | Appropriate Old Value |
| Stiff Lower Spine | Stiff Lower Spine |
| Flexible Lower Spine | Flexible Lower Spine (male actor) |
| Very Flexible Lower Spine (e.g. dancer) | Flexible Lower Spine (female actor) |
The last value is useful for slow plastic motions.
- Batch processing now supports the animation export (as a separate step).
- Usability improvements of 3D tools:
- Character skin is transparent for clicks on the elements of the Move and IK tools.
- Hit area is increased for the elements of the Move and IK tools.
- Highlighting active items under the mouse pointer in 3D viewport.
- Continuity of Euler angles is maintained in exported BVH, FBX and SMD files as described here.
- Indication of unsaved changes in the current project. Request to save changes before operations leading to closing the project (e.g. exit from the program).
- The Close Project menu item.
B U G F I X E S:
- In rare cases iPi Mocap Studio crashes during initialization of Sound device.
ver. 2.4.1.156
- Alternative calibration procedure for Dual Depth Sensor Configuration using flashlight.
- See this article for details.
- Further improvements of Jitter Removal.
B U G F I X E S:
- Fixed bug with support of multiple monitors.
- Fixed bug with incorrect clavicle position for 3D Max Biped and some other rigs (the rigs with default pose different from T-pose were affected).
- Fixed bug with mouse clicks in 3D view port after window resizing and/or splitter movements.
ver. 2.4.0.154
- Multiple actors support (Standard edition only).
- Multiple video cards support (Standard edition only).
- Batch processing (Standard edition only).
- Removed 2GB file size limitation for video export.
- Official support for tracking with 8 color cameras (Standard edition only). Support for 8 cameras is especially actual for multiple persons tracking.
- Recent releases already support 8 PS Eyes, but this feature is marked as "experimental" (there is a corresponding warning). In this release we just remove this warning. Some of our customers successfully track with 8 cameras for a long period of time, so we may consider it as stable now.
- Minor improvements of tracking accuracy.
- New Jitter Removal algorithm now preserves more details of the motion. Default value for Jitter Removal changed to 2.
- Inverted mouse wheel behavior in viewport.
- A motivation for this change was to make the behavior consistent with multi-touch "pinch to zoom" gesture, as well as with the majority of other apps. In the future releases this may become a user-defined setting. Sorry for inconvenience.
- Minor improvements in look-and-feel of Jitter Removal Options dialog.
- Tabs area width is restored from the previous launch of application (same as with window size).
B U G F I X E S:
- Fixed video opening error when project and video are located on different drives.
ver. 2.3.2.150
- Audio playback support.
- Version 2.2.0.24 or later of iPi Recorder is required for audio recording.
- MRU lists for poses in the context menu for a hand key frame.
- Recently saved/loaded hand poses are automatically put to the context menu for hand key frames of the corresponding hand, just below the standard poses. So to apply one of those poses you do not need to click Edit > Load Pose from File, then Ctrl + V. Just open context menu for a key frame and choose a pose.
B U G F I X E S:
ver. 2.3.1.149
B U G F I X E S:
- Fixed several issues when running with non-default DPI settings (e.g. 125% fonts)
ver. 2.3.0.148
B U G F I X E S:
ver. 2.3.0.147
B U G F I X E S:
ver. 2.3.0.146
- Changes in timeline:
- Tracking option for spine:
- Removed 90/180 degrees setting (no longer needed - auto-detected in new version).
B U G F I X E S:
ver. 2.2.1.145
- Tracking improvements:
- Improved spine tracking.
- UI improvements:
ver. 2.2.0.144
- Go to parent bone ([)
- Improved actor's model.
B U G F I X E S:
ver. 2.1.3.143
- Copy Pose of Selected Bone - copies rotations for selected bone to Clipboard. For paste use Paste Pose menu item.
- Copy Pose of Selected Bone with Children - copies rotations for selected bone and all its children to Clipboard. For paste use Paste Pose menu item.
- If video from depth sensors like MS Kinect or ASUS Xtion has RGB channel then now you can colorize 3D point cloud using data from RGB camera. To turn on this feature please use View -> Color Point Cloud with RGB Data menu item.
- Added iPiMocap: namespace only for MotionBuilder-optimized FBX output (Export -> For MotionBuilder (FBX, BVH) menu item).
B U G F I X E S:
ver. 2.1.2.142
B U G F I X E S:
ver. 2.1.2.141
ver. 2.1.1.140
- Small UI improvements:
ver. 2.1.0.139
- More compact project files.
B U G F I X E S:
ver. 2.0.1.138
ver. 2.0.0.137
B U G F I X E S:
ver. 2.0.0.135
B U G F I X E S:
ver. 2.0.0.134
B U G F I X E S:
ver. 2.0.0.133
B U G F I X E S:
ver. 2.0.0.132
B U G F I X E S:
ver. 2.0.0.131
B U G F I X E S:
ver. 2.0.0.130
B U G F I X E S:
ver. 2.0.0.129
- New skeleton.
- New project wizard.
- Improved foot tracking.
- Improved shoulder tracking.
