IPi Mocap Studio Changelog
Revision as of 19:42, 19 September 2014 by VMaslov (Talk | contribs)
ver. 2.6.1.165
Version 2.6.1.165
Sep 19, 2014
Download-24.png  Download
 B U G    F I X E S:
ver. 2.6.1.164
Version 2.6.1.164
Jul 29, 2014
 B U G    F I X E S:
ver. 2.6.1.163
Version 2.6.1.163
Mar 11, 2014
 N E W    F E A T U R E S:
 B U G    F I X E S:
ver. 2.6.0.162
Version 2.6.0.162
Feb 21, 2014
 B U G    F I X E S:
ver. 2.6.0.161
Version 2.6.0.161
Feb 19, 2014
This is a tool for in-depth biomechanical analysis of human motions. It includes visualization of tracking data and its export to various formats.
    • Multiple Actors
    • Motion Controllers
    • Hand keyframing
    • Multiple GPUs
    • Batch Processing
    • Biomechanical Analysis
 B U G    F I X E S:
ver. 2.5.1.159
Version 2.5.1.159
Nov 6, 2013
 B U G    F I X E S:
ver. 2.5.0.158
Version 2.5.0.158
Oct 11, 2013
The last value is useful for slow plastic motions.
 B U G    F I X E S:
ver. 2.4.1.156
Version 2.4.1.156
Sep 7, 2013
 B U G    F I X E S:
ver. 2.4.0.154
Version 2.4.0.154
Aug 7, 2013
    See this article for details.
    Recent releases already support 8 PS Eyes, but this feature is marked as "experimental" (there is a corresponding warning). In this release we just remove this warning. Some of our customers successfully track with 8 cameras for a long period of time, so we may consider it as stable now.
    A motivation for this change was to make the behavior consistent with multi-touch "pinch to zoom" gesture, as well as with the majority of other apps. In the future releases this may become a user-defined setting. Sorry for inconvenience.
 B U G    F I X E S:
ver. 2.3.2.150
Version 2.3.2.150
Jun 10, 2013
  • Audio playback support.
 B U G    F I X E S:
ver. 2.3.1.149
Version 2.3.1.149
Apr 06, 2013
 B U G    F I X E S:
ver. 2.3.0.148
Version 2.3.0.148
Mar 08, 2013
 B U G    F I X E S:
ver. 2.3.0.147
Version 2.3.0.147
Feb 26, 2013
 B U G    F I X E S:
ver. 2.3.0.146
Version 2.3.0.146
Feb 25, 2013
  • Changes in timeline:
  • Tracking option for spine:
 B U G    F I X E S:
ver. 2.2.1.145
Version 2.2.1.145
Jan 18, 2013
  • Tracking improvements:
    • Improved spine tracking.
  • UI improvements:
Refine Pass
Color Picker Tools
Time Line Zoom
ver. 2.2.0.144
Version 2.2.0.144
Dec 13, 2012
    • Go to parent bone ([)
  • Improved actor's model.
 B U G    F I X E S:
ver. 2.1.3.143
Version 2.1.3.143
Nov 23, 2012
 B U G    F I X E S:
ver. 2.1.2.142
Version 2.1.2.142
Nov 08, 2012
 B U G    F I X E S:
ver. 2.1.2.141
Version 2.1.2.141
Nov 07, 2012
ver. 2.1.1.140
Version 2.1.1.140
Oct 13, 2012
  • Small UI improvements:
Select bone
MRU project list
Export animation button
ver. 2.1.0.139
Version 2.1.0.139
Sep 30, 2012
UI changes
  • More compact project files.
 B U G    F I X E S:
ver. 2.0.1.138
Version 2.0.1.138
Aug 04, 2012
ver. 2.0.0.137
Version 2.0.0.137
Jul 19, 2012
 B U G    F I X E S:
ver. 2.0.0.135
Version 2.0.0.135
Jul 03, 2012
 B U G    F I X E S:
ver. 2.0.0.134
Version 2.0.0.134
Jun 30, 2012
 B U G    F I X E S:
ver. 2.0.0.133
Version 2.0.0.133
Jun 17, 2012
 B U G    F I X E S:
ver. 2.0.0.132
Version 2.0.0.132
Jun 13, 2012
 B U G    F I X E S:
ver. 2.0.0.131
Version 2.0.0.131
Jun 07, 2012
 B U G    F I X E S:
ver. 2.0.0.130
Version 2.0.0.130
Jun 02, 2012
 B U G    F I X E S:
ver. 2.0.0.129
Version 2.0.0.129
Jun 01, 2012
  • New skeleton.
  • New project wizard.
  • Improved foot tracking.
  • Improved shoulder tracking.
