IPi Mocap Studio Changelog
Revision as of 15:14, 3 April 2019 by Andrew (Talk | contribs)
Here you can find history of recent versions of iPi Mocap Studio. iPi Mocap Studio has built-in auto update functionality. Auto update feature is configured so that checks for update are made once per day. It helps to reduce the start time of the application. If you want to update ASAP — you can use the Help > Check for Update menu item. Note that both these features require Internet connection. Alternatively (in case of troubles with auto update), you can download and run the updated installation program from our website.
ver. 2.6.1.165
Version 2.6.1.165
Sep 19, 2014
Download-24.png  Download
 B U G    F I X E S:
ver. 2.6.1.164
Version 2.6.1.164
Jul 29, 2014
 B U G    F I X E S:
ver. 2.6.1.163
Version 2.6.1.163
Mar 11, 2014
 N E W    F E A T U R E S:
 B U G    F I X E S:
ver. 2.6.0.162
Version 2.6.0.162
Feb 21, 2014
 B U G    F I X E S:
ver. 2.6.0.161
Version 2.6.0.161
Feb 19, 2014
This is a tool for in-depth biomechanical analysis of human motions. It includes visualization of tracking data and its export to various formats.
    • Multiple Actors
    • Motion Controllers
    • Hand keyframing
    • Multiple GPUs
    • Batch Processing
    • Biomechanical Analysis
 B U G    F I X E S:
ver. 2.5.1.159
Version 2.5.1.159
Nov 6, 2013
 B U G    F I X E S:
ver. 2.5.0.158
Version 2.5.0.158
Oct 11, 2013
The last value is useful for slow plastic motions.
 B U G    F I X E S:
ver. 2.4.1.156
Version 2.4.1.156
Sep 7, 2013
  • Further improvements of Jitter Removal.
 B U G    F I X E S:
ver. 2.4.0.154
Version 2.4.0.154
Aug 7, 2013
  • Recent releases already support 8 PS Eyes, but this feature is marked as "experimental" (there is a corresponding warning). In this release we just remove this warning. Some of our customers successfully track with 8 cameras for a long period of time, so we may consider it as stable now.
  • A motivation for this change was to make the behavior consistent with multi-touch "pinch to zoom" gesture, as well as with the majority of other apps. In the future releases this may become a user-defined setting. Sorry for inconvenience.
 B U G    F I X E S:
ver. 2.3.2.150
Version 2.3.2.150
Jun 10, 2013
  • Audio playback support.
  • Recently saved/loaded hand poses are automatically put to the context menu for hand key frames of the corresponding hand, just below the standard poses. So to apply one of those poses you do not need to click Edit > Load Pose from File, then Ctrl + V. Just open context menu for a key frame and choose a pose.
 B U G    F I X E S:
ver. 2.3.1.149
Version 2.3.1.149
Apr 06, 2013
 B U G    F I X E S:
ver. 2.3.0.148
Version 2.3.0.148
Mar 08, 2013
 B U G    F I X E S:
ver. 2.3.0.147
Version 2.3.0.147
Feb 26, 2013
 B U G    F I X E S:
ver. 2.3.0.146
Version 2.3.0.146
Feb 25, 2013
  • Changes in timeline:
  • Tracking option for spine:
 B U G    F I X E S:
ver. 2.2.1.145
Version 2.2.1.145
Jan 18, 2013
  • Tracking improvements:
    • Improved spine tracking.
  • UI improvements:
Refine Pass
Color Picker Tools
Time Line Zoom
ver. 2.2.0.144
Version 2.2.0.144
Dec 13, 2012
  • Warning. Projects with motion controller data cannot be open by previous versions of iPi Mocap Studio.
    • Go to parent bone ([)
  • Improved actor's model.
 B U G    F I X E S:
ver. 2.1.3.143
Version 2.1.3.143
Nov 23, 2012
 B U G    F I X E S:
ver. 2.1.2.142
Version 2.1.2.142
Nov 08, 2012
 B U G    F I X E S:
ver. 2.1.2.141
Version 2.1.2.141
Nov 07, 2012
ver. 2.1.1.140
Version 2.1.1.140
Oct 13, 2012
  • Small UI improvements:
Select bone
MRU project list
Export animation button
ver. 2.1.0.139
Version 2.1.0.139
Sep 30, 2012
UI changes
  • More compact project files.
 B U G    F I X E S:
ver. 2.0.1.138
Version 2.0.1.138
Aug 04, 2012
ver. 2.0.0.137
Version 2.0.0.137
Jul 19, 2012
 B U G    F I X E S:
ver. 2.0.0.135
Version 2.0.0.135
Jul 03, 2012
 B U G    F I X E S:
ver. 2.0.0.134
Version 2.0.0.134
Jun 30, 2012
 B U G    F I X E S:
ver. 2.0.0.133
Version 2.0.0.133
Jun 17, 2012
 B U G    F I X E S:
ver. 2.0.0.132
Version 2.0.0.132
Jun 13, 2012
 B U G    F I X E S:
ver. 2.0.0.131
Version 2.0.0.131
Jun 07, 2012
 B U G    F I X E S:
ver. 2.0.0.130
Version 2.0.0.130
Jun 02, 2012
 B U G    F I X E S:
ver. 2.0.0.129
Version 2.0.0.129
Jun 01, 2012
First public release of iPi Mocap Studio 2. If you're user of iPi Studio 1.x then please visit Migration from v1.x to v2.0 article.  N E W    F E A T U R E S:
  • New skeleton.
  • New project wizard.
  • Improved foot tracking.
  • Improved shoulder tracking.
